Adding custom slab doors to cut ready
Scott Marshburn
Post by Scott Marshburn »
Is it possible to add a slab door with custom profiles to cut ready ? Hive tried to make a slab door with profiles ie a beveled shaker door. When I send it to the customer and they load it into their cut ready machine it will not include the cut path for the profile it just nest the door as a slab door. The only way I can get it to work is to use a back with the pocket and profile but this adds a lot of extra work for the user to get what they need and then they can not add it as a door to their drawing
Clint Buechlein
Company Name: Thermwood Corp
Re: Adding custom slab doors to cut ready
Post by Clint Buechlein »
Scott,
Not at the user level. There is no user interface to change profiling settings so anything profiled is not supported. Anything you can get done profiling wise will likely be a happy accident.
