Is it possible to cut flips for deck and tops with offall sheets. If try to use a offall sheet with a barcode it will not allow me to use it as a sheet that I can flip from B to A side. Even if the offall sheet is rectangular and laying against all 3 popup pins.
Thanks!
Cutting Flips with offall sheets
Eric Schuyler
- Company Name: Conejo Woodworks
Thomas strembitsky
Re: Cutting Flips with offall sheets
In control nesting in settings under flip ops first make sure "do not allow flip parts on added sheets or off-fall" is not checked off.
Its the second button from the top
http://www.trueform.ca
CS43 cnc
CS43 cnc
