Creating new appliances
steven peters
Post by steven peters »
Is there a way to create a usable appliance from a jpeg downloaded from the net? I'm trying to creat a GE stainless fridge with the freezer on the bottom.
Steven,
You can create a Display Cube the size if the fridge and crop and use the jpeg image for the cube. Be sure to check stretch instead of tile when you use the image.
steven peters
Thanks, it sounds easy enough.
Michael Yeargain
Post by Michael Yeargain »
Can he do it? :wall:
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Steven,
Here is a 3D model of a bottom freezer fridge if you would like to use it. It isn't great but it might get you by. You just place these files in your Imports folder and you will be able to open them as Display objects. You can change the textures on the parts by opening this object in the Display Parts Editor and right clicking on each part and choosing a new texture. This is supposed to be a jennair 36 the size is 36Wx27Dx68T you can scale this part in the Cabinet/Assembly editor
jennair_36.zip
(32.63 KiB) Downloaded 1050 times
steven peters
Thanks, I'll use your double door fridge. It looks a lot better than a display cube with a jpeg on it.
Lee Morris
Post by Lee Morris »
Thanks for this fridge. I have a customer who is scrutinizing every detail and actually having the correct model is far better than trying to explain why the stock fridge from the appliance list doesn't look right .
Thanks again!
Lee
Lee
If the only tool you have is a hammer,
every problem looks like a nail.
Joe Dusel
Post by Joe Dusel »
If it's a GE Monogram you could just download the CAD file, convert it to STL, import it to eCabs in the Display Part Editor and then save it with the stainless steel texture as an HSF file which you can now use as a display object.
Try here http://www.monogram.com/selectionguide/
Then click on the type. product you want.
Then click on the Model Number
Then on that page click on Product Documentation
Scroll down that page till you see the link for the CAD Download
The result will be something like the attachment.
Joe
ge mon 36 inch bottom freeze.hsf
(72.02 KiB) Downloaded 1063 times
ge mon 36 inch bottom freeze.jpg (4.27 KiB) Viewed 21093 times
Lee Morris
Thanks Joe. The customer had picked the Jenn-air. I'll put the GE in as an option for the next job.
Lee
Al Navas
Re:
Post by Al Navas »
Joe Dusel wrote:... just download the CAD file, convert it to STL, import it to eCabs in the Display Part Editor and then save it with the stainless steel texture as an HSF file which you can now use as a display object...
Thanks, Joe.
Can you provide some details?
1. I don't have AutoCad. How do I convert?
2. Are there any free converters?
Please let me know.
Al
http://sandal-woodsblog.com
Accutrans can be used to convert files.
Al Navas
Post by Al Navas »
Accutrans does not read the DWG file format, although it does export to STL.
What else is available that is free, or cheap? Need to go DWG --> STL .
Al
Lee Morris
Al
TurboCad can read and save DWG and DXF files. The Learning Edition is version 4, ImsiSoft is currently selling version 11 and I think they hope you'll get hooked and buy the latest verion. I have had problems opening some Dxf and Dwg files, maybe it is because of the version of AutoCad that was used to save them
http://www.freecad.com/cgi-bin/dcd/html ... ndex-5.htm
Go down to the 7th block on the web page and click on the TurboCad LE title at the top of the block
Good Luck
Lee
Al Navas
Post by Al Navas »
Thanks for the suggestion, Lee.
The following is a short extract from the freecad link you provided - we probably should avoid installing this version of TurboCAD on WinXP:
Note:
IMSI has stopped offering a freeware copy of TurboCAD LE at their own website due to installation problems with Windows XP.
I have been looking on eBay for something newer than version 10, and it appears there are many to be had for a very reasonable price. I wonder if anyone has had good experience buying TurboCAD on eBay?
Al
Michael Yeargain
I have been working on quite a few files for compilation into a possible CD format. Kind of a copy paste and you're ready to use the library.
Here is a site link I think. try it.
This is a test...
http://www.freecad.com/cgi-bin/dcd/dcd. ... _files.zip
32Gigs DDR4
Corsair RM650
