dadoing faceframes to case
Don Nichelson
Post by Don Nichelson »
I cannot figure out how to set up dadoing my faceframes to cabinet. There doesn't seem to be an option for that. In the past I have just made sides, top and deck 1/4\" wider. Is there a way to set this up?
Don Nichelson
Sorry
I'm sorry I already posted this question. Is this function up and running yet?
Dave O Jeffries
Company Name: THE WOODSHOP
dado face frames
Post by Dave O Jeffries »
DON just use a negative inset on the part [side top or deck]
Post by Forrest Chapman »
Don,
Hang in there. It won't be much longer.
Michael S Murray
Post by Michael S Murray »
Sounds like Forrest has some insider info. here!Come on Forrest share with us, we wont tell any one else!!!!!!!!
Mike Murray
mike@versatilecabinet.com
Mike,
What I know is the Thermwood guys are working very hard to implement this feature. Beyond that I can't talk about it. Besides I'm not going to be the one to try and steal Ken's thunder. Just trying to give Don something to look forward to.
Michael Yeargain
Post by Michael Yeargain »
Great response forrest :roll:
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Michael S Murray
Forrest,
I was just joking, obviously. I appreciate all the hard work the guys at Thermwood are doing, I cant imagine the complexity of it all, I have my hands full just trying to keep my little business going. I can only imagine what this software will be in a couple more years.
Mike
p.s.
But if you dont tell me I am going to go down to thermwood and go office to office until some one gives it up!! :lol:
Mike Murray
Michael Yeargain
They might be open monday :lol:
32Gigs DDR4
Corsair RM650
Mike and Mike,
I get it. :) But I've said enough. :wink: Now if you don't let this go I'm going to get in trouble guys. :joker:
Brian Shannon
Post by Brian Shannon »
I've never used this method to attach a faceframe. Do you guys run the dado on the Style all the way through. I use pocket holes and screws. How does the dado effect the area where there are screws from the rails?
Brian
Michael S Murray
Hey Brian,
I DONT do face frame, but when I do, or when I use to a lot, I had a pretty good system. To try to explain, I would cut all my face frame material to size, then I would cut a 1/4\" w.x 3/8\" d. dado in the back, 1/2\" in from edge, or really the thickness off my box material. We use 1/2\" plywood. Then you would cut a 1/4\" wide tongue on your box. This would be inserted in the groove of the face frame. depending on how you orientated the panel when you inserted it, you would end up with a 1/4\" scribe for cabinet to cabinet or if you rotated the panel 180 d. you had a flush panel for end of run. Same setup for both, you only had to watch the finish on the exposed end run cabinet. Same way for the deck, you could make it flush or 1/4 lip depending on how you inserted panel. To answer your ?, we did not use pocket holes and dado's in combination, we just glued the panel in dado and the either clamped for finish ends or angle nailed a few brads through the side panel into face frame for butt cabinets.
Hope this helps,
Mike Murray
Brian Shannon
Thanks Mike,
I think I understand how you did it. Do you build your Faceframes with pocket holes and screws? I'm wondering about the faceframe screws going into the Style dado, before the frame even goes onto the box.
Brian
Michael S Murray
Yes we do pocket hole our faceframes. We use a 1-5/8 wide rail and style for the most part and even at that minimum width we dont have trouble with the pocket hole screw going through the dado. We only use one screw per joint as by the time you glue it and then dado and glue the box to the frame, it is a very strong joint. But, remember, you are talking to a guy who DOES not build face frame cabinets!!!
Hope this helps
Mike Murray
Brian Shannon
I use 1 1/4\" faceframe screws. I haven't checked but I guess with 1/2\" to bite into on the Style, the screw may be O.K.. Thanks for the help Mike.
Brian
