Help on Ruff edges
Michael Vendryes
Help on Ruff edges
Post by Michael Vendryes »
I'm very new to the cnc world and recently had a couple of book cases made as test pieces before going on to build for customers, when I received the pieces back all the edges were very ruff and hairy and I had to sand them all down, is this normal?
any suggestions?
Mark Hesketh
Company Name: Paris Kitchens
Post by Mark Hesketh »
what type of cutter bit are you using? upcut? downcut? if you are using a downcut, you may find the bottom edge turning out rough. if you use an upcut, the top edge will be rough. we use a combination up-downcut bit and that gives us the best edges.
another place where you might get rough edges is if your part overhangs your spacer board at all. if the cutter bit is cutting the material where there is nothing underneath it to support that edge, it can give you a rough edge.
hope this helps :)
Post by Ryan Hochgesang »
Michael,
As Mark has mentioned, type of cutter will make a differance in the cut quality; cut feeds and speeds can also have some affect on the quality of cut. If a cutter has excessive wear and is dull, this could also be another factor.
David Hall
Post by David Hall »
In addition to the other excellent cut quality suggestions, this is the \"Normal\" result of climb cutting many veneer core materials. :roll:
\"Suggestions?\" ... yes, See your Private Messages
Dave
David Hall
Hall's Edge Inc.
eCabinets Machining Services
http://www.HallsEdge.com
Rob Davis
Post by Rob Davis »
Dave, if their private messages have the answer, why not tell all of us?
David Hall
Rob,
The \"answer\" is to not climb cut VC material.
My \"suggestion\" was non-technical and less than complimentary so I chose to keep it out of a public discussion.
Dave
David Hall
Hall's Edge Inc.
Post by Forrest Chapman »
As David suggest conventional cutting will leave more and more fuzz as the bit loses its edge. While the downside to cutting conv. is when the bit leaves an lipped edge on skinned parts. Hopefully Thermwood will help us resolve this issue by allowing a roughing pass or multi directional outline cuts. I hope you get your problem figured out.
Ps. David, are you as crazy busy as I am? I haven't seen you on the forum lately.
David Hall
Hi Forrest,
I believe you meant to say climb cutting will leave the fuzzy edge.
Yes, we're very busy. Busy is good; but doesn't leave much time for the fun stuff.
Dave
David Hall
Hall's Edge Inc.
Dave,
Thanks for the correction. Yes, no fun stuff here either.
