Locking up when saving
Jerry McClain
Post by Jerry McClain »
I have a layout and am trying to put a countertop on it and I can get the tops on just fine but when I try to save it the system locks up. Can anyone help me with this. I am attaching the layout.
Samantha Collier Counters and molding.zip
(4.92 MiB) Downloaded 732 times
JLM
Theodore R Fountain
Post by Theodore R Fountain »
I had the same thing happen. It only froze when i tried to save the job with a countertop placed on an island made of 2 cabinets. All the other countertops saved fine. but i was able to narrow it down to the one countertop. I got around it by useing a display cube instead.
Brian Shannon
Post by Brian Shannon »
Same here. It must be a countertop bug...
Al Navas
Post by Al Navas »
You may try doing a Search here, using the terms \"countertop\" and \"bug\", and selecting the radio button \"search for all terms\". I got around 8 hits.
Al
http://sandal-woodsblog.com
I think there was an issue with having three c-tops in a room.
Michael Yeargain
Post by Michael Yeargain »
I think it was Rick Deskins who discovered a work around while this is fixed.
If I am wrong I am sorry for the incorrect credit.
Take the last countertop you place into a room, into the part editor, click return, and go back to the layout room. It should save now. This should help.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Justin Melhiser
Post by Justin Melhiser »
Jerry
I am taking a look at this job file. I will let you know what I find out.
Walker T Scott
Post by Walker T Scott »
This is a known issue and will be fixed in the next patch. Here is a link to the original post. There is a work around just simply take a countertop to the part editor and then return you don’t have to do any thing to the countertop and it should save fine.
http://www.thermwood.com/forums/viewtop ... highlight=
walker
Michael Yeargain
Re:
Michael Yeargain wrote:I think it was Rick Deskins who discovered a work around while this is fixed.
It appears that I was incorrect. Gene Kimmi was the one who discovered the work around. Sorry Gene.
32Gigs DDR4
Corsair RM650
Gene Kimmi
Post by Gene Kimmi »
Mike,
No problem. More important than the credit for finding a work-around, is that one was found and we can all continue using this great software without that problem.
As I was banging my head against the wall trying to save the job I was working on, I decided to take the top to the part editor and dock the corners off. I found that this let me save the job without the lockup problem.
Gene Kimmi
Lenovo W540 windows 8.1 Pro
Samsung 256 SSD Drive
Jerry McClain
Just an update for you folks who helped me with this, there were other problems with this job that Justin couldn't recreate but when we sent him screen shots comparing his machine to ours there were differences. We sent some files for him to look at and hopefully he will figure out what happened on this job.
JLM
