Hi,
I'm in the middle of designing a kitchen and I started getting this error on the upper cabinet doors when the program tries to add them. The first upper added the doors no problem but now it won't work on any cabinet. Any help would be greatly appreciated.
Could you post the cabinet so we can take a look at it? What kind of doors are you using? If there Conestoga which one and what profile, bead, raise did you set as default?
I'm not sure how you post the cabinet on here. It is a Conestoga door, crp-20, fp profile, regular bead, reverse G cove. The problem seems to come from the size of the door. a door sized over 15 in. wide works just fine, but a door sized under 15 in. gives me the error.
thanks,
Randy
There seams to be a parasolid failure when creating that door at that height with that profile. I changed the profile to b-2 profile and it worked fine so you can do that or make sure your opening height for your doors are 10 inches or higher. I have the programmers looking in to this. Sorry for the inconvenience
