Lost leader in line drawing editor!!!!!
Matt Fauller
Post by Matt Fauller »
I was just doing another measured drawing as usual, and my leader no longer works! I am able to type text, but no line and arrow appears. I've tried everything. Please help. Attached is the job I was working on when it happened if that helps.
All help is greatly appreciated.
- Matt
wet bar.jpg (13 KiB) Viewed 6570 times
Matt Fauller
sorry, here is the correct attachment....
wet bar.esa
(6.21 MiB) Downloaded 656 times
Al Navas
Post by Al Navas »
Matt,
I worked with your assembly a little bit. My system was a bit sluggish when I was working with it - and THAT was quite unusual.
Soooo.... I looked at memory use:
1. Peak Commit Charge: 1.3 GB !
2. System cache: 793 MB
It seems that this large job is consuming a LOT of memory, and you might run up against max memory on your system.
My guess: The hardware you installed on the components of this assembly.
My recommendation: To get the dimensioned drawings, remove the pulls and all other hardware, and try again. Let us know if it works for you.
Al
Matt Fauller
Thanks for taking the time Al. However, even when working on a blank page, the leader doesn't show. The same for tables too. But they do print which is weird. I did a system restore, and used the repair utility from the installation disk, and still nothing.
I need a leader!!!!!!
