Having Trouble Adjusting Partition
I am having a problem to adjust a partition. I install the partition and it automatically seems to center itself in the middle of the cabinet ends. This seems to be ok however, when I attempt to change the values so I can position the partition where I want it to be, I get no results. It will not move regardless of what kind of values I put in. This one is a puzzle. Help is appreciated.
Dave
Be sure to highlight the opening to one side or the other of the partition, type in the opening width you desire, then hit enter. The partition should move to the width you entered. You can also move it manually by highlighting the partition, hold down shift key, place the pointer on the partition, hold down left mouse button, and move it left or right.
Mike
Mike
Maybe the short video I attach will help with the visuals. I included adding one partition, and several shelves.
Previous posts have already explained the following better:
After adding either a partition or a shelf, first select the item within the appropriate editor (Shelf/Partition Editor, for example) by clicking once on it, and, while pressing the SHIFT key, use the mouse to drag the item to position it. The same goes for shelves.
I don't know if the image quality is good enough when playing this at Full Size, as the encoder in Photobucket did something to the *.wmv file... You may have to temporarily allow pop-ups, and select Full Size at the bottom-right of the image in Photobucket in order to see everything properly.
Al
Edit to add: The codec instruction suggests to use 800 x 600 screen resolution to view the video file full-screen. I have a feeling it has to do with the lossy conversion.
Al
I know you weren't, Rick. I was just pulling your chain . BUT your suggestion was great, and the alternate way of doing it with the dialog box completed the demo nicely. Thanks for mentioning it.
I agree - this would be a terrific way of illustrating techniques in the Part Editor (especially the Part Editor).
Al
Al
