Help on color change on Clock R&S
The clock was black I wanted to change it all to white.
It will not change the rails and Stile to white.
I get (There was a problem in boolean Outline and Route bodies) :?:
Clock.zip
(203.67 KiB) Downloaded 293 times
Todd Miller
Post by Todd Miller »
George,
Select the cabinet (double click)
Next, go into your construction settings
Then, go to the Faceframe tab
After that, click the \"go to page 2\" button, in the lower right corner.
Next, change the board stock material so something with a white texture.
Then, click the all button to change all of your old material to that new material.
Then, click OK
This should update you FF
Note: You may need to create a white board stock material if you do not have one in your material list.
NO luck Todd
I have tryed Oak,Cherry,Maple No luck.
It will start to work Oak will come up then I get
It will go back to Black :?:
Chimies C.jpg (58.75 KiB) Viewed 2845 times
Todd Miller
I addition to what I said above, you will need to have the \"common with door\" box unchecked. This box is found in the FF construction settings, page 2.
clock.esa
(672.02 KiB) Downloaded 293 times
Thank You Todd
I put your file in with new mat. in and it worked fine. I did have the box unchecked. Here is the whites that I had in my file but yours worked
