Problem placing cabinets in rooms
Brian Widiker
Post by Brian Widiker »
Hello
I am starting to create a room layout. When I try to place corner cabinets in the corners with the mouse or with the arrow keys, the cabinets bounce off of the wall. When I do get the cabinet close, it looks like it is in the wall, and when I place a second cabinet next to it, the face frames won't line up. The same thing happens while placing two regular wall cabinets next to each other, while placing the second cabinet it bounces off of the first one or won't get within a few inches of the other cabinet.
Brian
P.S. Is there anything in the works as far as an update for the e-cabinets made easy manual? It would be easier to learn with a manual that matched the program.
Brian
Wally Schneeberger
Re: Problem placing cabinets in rooms
Post by Wally Schneeberger »
Right click when placing and choose FREEHAND then use the SHIFT with the ARROW keys to place your cab. Make sure you highlight your cab and ASSOCIATE TO WALL before you try an elevation.
Joseph Fusco
Post by Joseph Fusco »
Brian,
You might just try setting the Insert mode to "align to back". The corner cabinet should then just "snap" into the corner. You should start with all your cabinets that way then change them as needed. :D
Dennis Englert
Post by Dennis Englert »
You will have similar issues placing a cabinet if the walls are not square.
Brian Widiker
Hello
Thanks everyone for your responses. I tried them all and it still did it. It looked like the walls were square (when I used the cross-hair as a carpenters square). I guess they weren't. I made a new room using the square tool, and the cabinets worked just fine.
:beer:
Brian
Brian
Dennis Englert
Brian,
When walls are drawn one wall at a time, you'll need to invoke the "Ortho" option from the right-click menu or press the "F8" function key. This function restricts the drawing of a wall to either a horizontal or vertical direction. You can also check the angle of the walls by left-clicking on the wall, then left-click on one of the blue dots or endpoints of the wall. On the left-side menu there will be a description of the length of the wall as well as the angle.
Dennis
Brian Widiker
Dennis
Thanks for the information .When i get a chance i'll try it out.
Thanks For Everyones Imput
Brian
O SO MUCH TO LEARN !!!!!!!!!!!!!!!:lol:
Brian
Paul Ford
Post by Paul Ford »
Also make sure you draw your walls in a clockwise motion. When you draw your walls you should see an arrow pointing to the "Face" side of the wall, then when you go into the detail room area you should see a pink line around the inside of the wall where the cabinets are to be places.
Something like this...
wall editor.jpg (18.27 KiB) Viewed 13996 times
