After looking at a number of designs by other folks using ecabs, I realize that there are trim pieces that are not included in ecabs trim section. Does anyone have any libraries that they would share (or even sell) that could be added to my trim library. I am especially interested in turned colums (or any kind of columns - rope, smooth, etc.). Or are there any other companies from which I could download another library?
Thanks for any help.
Ron Porter
Any trim libraries out there?
Ronald Porter
David Norton
- Company Name: Custom Trim and Millwork
Re: Any trim libraries out there?
Ron,
I use The CD I got from Raymond Enkeboll , You can use their .dwg files.And using the proggie Accutrans change the file type to a .stl file ,
which Ecabs can use. Hope this helps somewhat.
D. norton
D. norton
Dave Norton
Ronald Porter
David,
Thanks for the reply. Do I order the CD from Enkeboll's website? Or can I simply download it?
Also, I have read some other posts about Accutrans. Is it a fairly straight-forward process to convert the files, or is there a learning curve. How much is the software?
Sorry for all the questions, I am just really getting into ecabs, and getting setup is taking a little more effort than I had thought.
Thanks again for any help.
Ron Porter
Ron Porter
- Damon Nabors
Ron, if you need a specific molding or something, I can draw it up in ArtCam for you. Its alot easier, and can be brought into ecab as a DXF and converted to a .tol
Damon
Damon
Damon Nabors
DanFecteau
Do you know where I can find some stl files of woodcarving ? or 3d dwg that I could convert and would look good ? I have a thermwood CNC and Mastercam, Mastercam Art, Autocad and eCab. I already know vectorart and vectorclip.
Thanks.
Thanks.
- Damon Nabors
