Increase size of rails and stiles
Tom Giacchina
Post by Tom Giacchina »
Hi
I am using the TW-10 Conestoga as the basis for a door. I want the stiles/rails to be 4" wide for that modern look. I can set the width in the sizing details for cut list but it doesn't change the view of the door. I would like to "see" this so I can determine the looks of door / drawer layouts. Any ideas on how to do this?
Tom
Damon Nabors
Re: Increase size of rails and stiles
Post by Damon Nabors »
Tom, you can take a MDF door and profile the door with a raised panel tool and apply it to the cabinet for display purposes. The grain will run the wrong way on the rails, but you be able to get a feel for the proportions of your layout. Here are two doors. The one on the left is a mdf door with 4" rails/styles, the one on the right is the standard conestoga crp-10
18x30 door.jpg (30.12 KiB) Viewed 11868 times
Damon Nabors
Tom Giacchina
Thanks I am new to this. Which profile tool did you use? I tried a bunch both interior and exterior with no change when resetting the image.
Tom
Mike Seisser
Company Name: NCB Inc.
Post by Mike Seisser »
Here's a 5 piece door with 4" rails and stiles, which is actually a cabinet. (It has all parts deleted except the face frame and back.) Resize as you would any other cabinet.
HTH
Mike
4 inch Rails n Stiles.hsf
(1.32 MiB) Downloaded 1127 times
4 inch Rails n Stiles.jpg (7.33 KiB) Viewed 11852 times
Damon Nabors
Tom,
go to the "Door/Drawer Front Designer" icon
Select Source:
a.Thermwood
b.Standard
c.Thermwood Standard Door
d Layout Tab
1: Stile Width
2: Rail Width
e. Save door
Then you will have a door like Mike Seisser designed.
I forgot about this method.
Damon Nabors
jerry johnson
Post by jerry johnson »
Tom, use a Thermwood door template and you can make the stiles and rails what you want. 8)
Tom Giacchina
Thanks that was easy!
Now as an assembly when I drop it in as an upper cabinet with doors, it is putting it on the floor. How do I raise them or not lose the spec from upper cab to assembly.
Tom
Tom Giacchina
Never mind I figured out that I can save the cab with doors as a cab, therefore it keeps its construction info. I need to do so more reading on when to use assemblies. Thanks for all of the responces.
Tom
