object elevation
matt omeara
object elevation
Post by matt omeara »
In the detail room area of custom layout, I've found that when I try to locate objects by modifying their position value that the value I specify doesn't "take", or doesn't take as I specify. For example, I'll type 63 for the value to the base of the wall and then press Return. But as soon as I press return, the value 62 shows up rather than 63. This has happened on a lot of objects. What's happening to cause this?
Glenn Warner
Re: object elevation
Post by Glenn Warner »
Hi Matt,
I can duplicate this. Only happens to some cabs and not others. Looks like a bug to me. The arrows work fine to move by the "move increment".
matt omeara
I can get around this by typing 63 when I really want 62.
As I'm new to this program, I'm not sure if it's me not understanding something about the software, or if I'm hitting a bug. After running into a lot of these little glitches, I'm realizing that it's the software. But I like the simplicity and flexibility of this program. There always seems to be a fairly easy work around.
Mike Seisser
Company Name: NCB Inc.
Post by Mike Seisser »
I've never quite isolated what the cause of this bug is either, and it's been around awhile. The only workaround I've been successful with is a restart of the software, sometime sin conjunction with a reboot.
Are you entering the inch or mm designation with your value before hitting return?
Mike
Justin Melhiser
Post by Justin Melhiser »
Matt
Post the file or email it to me. I will take a look at it and pass it on to the programmers if needed.
Glenn Warner
Justin,
Attached is the job file. Both cabinets are set to 0" from floor. Cabinet on the left is always 1 1/8" off.
Bug report 2-25-2007.esj
(1.16 MiB) Downloaded 648 times
Justin Melhiser
Glenn
This seems to be fixed in V5.2. However for now type in 1.125 in the bottom box and it will place the cabinet at zero.
