Line drawings
Lee Gernandt
Line drawings
When I take a cabinet into line drawing editor, it looks fine, but when I print it out, it shows the shelves behind the doors and raised panel doors, even though they are flat panel doors everywhere else.Is there a setting I need to adjust? If so, any tips to point me in the right direction would be greatly appreciated.
Re: Line drawings
Did you try changing your line enhancement to maybe 0 so the shelves wont show, as far as the flat panel doors showing as a raised panel never seen that before. Mark.
Derek Kruzner
Re: Line drawings
I got the same thing. Only some of the shelves showed up behind shaker style doors.
Lee Gernandt
Re: Line drawings
That's what I'm getting. Some shelves show, some don't, and all the panels are raised.
- Kerry Fullington
Re: Line drawings
If you are using a door with a Reverse G-Cove panel it might be the back cut lines that are showing up making it look like a front raised panel.
David Werkheiser
Re: Line drawings
Mark, Great tip on removing shelf lines, much cleaner drawings!
Thanks, David
Thanks, David
Lee Gernandt
Re: Line drawings
Seting the line enhancement to 0 did the trick. I thought it would be something simple.Thanks,Lee.
Re: Line drawings
Glad to help, Anouther trick Ive learned is that if you need to keep that line enhancement at a positive number to enhance your cabinets exterior details you can go up to the top left corner in your LDE and click on prt then highlight the doors rt click and say hide then highlight the individual shelves that you dont want to see. then rt click again and say show hidden items , now your doors are back and the shelves behind are still highlighted (you cant see that but they are) now rt click and say hide and your shelves are hidden. Comes in handy every once in a while. Mark.
