Counter display in line drawing
Having trouble getting a counter top to display in line drawing. Have tried the create counter, and dispaly panel without success. SInce I use allot of P.Lam for counter tops I want the counter to display so that I can nest it and machine the piece. To display the counter top in line drawing is a must since designers or architects have to sign off on the drawings for approval. Commerical shops will understand my dilemna the best. Can anyone help?
Re: Counter display in line drawing
David
If you create a room and place your cabinets in this room then add counter tops, you will be able to take the room to the LDE and your counter tops will show up in there.
Try associating those objects to a wall in the detail room screen otherwise if you just take an elavation to the LDE, it doesn't show up. Lee
