LEFT AND RIGHT BLIND DADOES ON PARTITIONS
John Pippert
Post by John Pippert »
Can you desiginate left dadoe on one partiotion and right on another in same cabinet? First time we really have looked at this, because we always used the cut sheet and did everthing inhouse. Now we have the opportunity to use a member to cut parts for us. We have a micro cabinet over cooktop surface, and it needs a left and right partition when you do the left and dadoe right it places it correctly, but when you place the right and dadoe left it leaves a double wide dadoe on the left partition.
Re: LEFT AND RIGHT BLIND DADOES ON PARTITIONS
Post by Forrest Chapman »
John,
Take the cabinet into shelf editor and highlight the partition you would like to change then go to constuction settings and change to the desired side. This will affect only the highlighted part.
John Pippert
We did this, but can't seem to get rid of the double half blind on the left partition
John Pippert
Justin Melhiser
Post by Justin Melhiser »
John
Will you send me this file, I would like to take a look at it. I will see if I get the same results.
