I am trying to bring in a DFX File which I can do, but when bringing it in the shape manager there isnt a way to rotate the part, so is there a way of doing this? Also when I take the DFX file into the line drawing editor I can then rotate but I cant then save the file again so I can use the rotated version within the shape manager, so again is there a way around this?
There is actually a very simple way to rotate any geometry 90 degrees (or others too) in eCabinet Systems by using the mirror functionality. (View my attached jpg and it will make sense) But the short of it is:
1.) Make a line that is 45 degrees some where (near the geometry, in the middle of it or even a 45 line that is within it already, does not matter)
2.) Select the geometry you want to rotate (the chain select method is handy for this)
3.) Select mirror, chose the line mirror option, select the 45 line and you have your 90 degree rotate.
Hope this helps.
Rotate 90 Via Mirror.jpg (53.28 KiB) Viewed 11006 times
