PART EDITOR HAS A MIND OF IT'S OWN
Al dedenus
Country: NEW ZEALAND
Post by Al dedenus »
I have a breakfront cabinet with a marble top,so created the top as a display cube,picked a marble image, and sent it to the part editor to cut.Problem is when I returned to the cab editor the marble image was striped.Made the attempt 3 times before it returned how it should.I've come across this a few times before.Anyone else having this problem??
Re: PART EDITOR HAS A MIND OF IT'S OWN
Al,
Post your cube.
I tried making cuts on a cube with a marble texture and all is well.
You can also highlight your cube then use File/Export to export the cube to the Display Part Editor where you can re-apply and adjust the marble image then save the top as a display object.
That might fix it.
Al dedenus
Kerry YOU DA MAN Heres the cubes as you can see I definitly had a few issues before I got it right
DISPLAY CUBE WITH MARBLE TOPS.jpg (18 KiB) Viewed 4668 times
Lamar Horton
Post by Lamar Horton »
Al I have had this problem with cutting sink hole is counter tops. Had to use a display cube like Kerry says.
Jason Gooch
Post by Jason Gooch »
I had this problem in the past - I'm pretty sure I just gave up and moved on.
www.appleboxwood.com
