Having a bear of a time with deleting hole pattern for adjustable shelves. Since the plans specify pilasters I have placed dados to receive the pilasters( some guys call then standards) and then I removed the check mark in the adjustable shelf tab. But the holes won't go away. They even show up in the nesting diagram. Need help.
David,
Take the cabinet into the shelf editor. Left click on the shelf so it has a green outline on it. Click on the construction settings button in the secondary tool bar. Switch fron fixed to adjustable shelf. You should now see that the "apply shelf holes" is checked. Uncheck it and click okay. This will rebuild the cabinet withoout the holes.
