In the cost sheet just before the labor section there is a Misc. section what is this. I have a Qty. of 2 with no dollar amount and I don't know what the 2 is.
Qyestion
- Gary Puckett
Qyestion
Justin Melhiser
Re: Qyestion
If you double click on the cabinet, then right click go to labor cost. What is in the field for misc 1 and misc 2?
- Gary Puckett
Re: Qyestion
Justin,
The misc. I have checked in the labor section shows up in the labor section and there is about 13 cabinets with a misc checked.
This is above the labor section and has a QTY of 2 and no dollar amount
Justin Melhiser
Re: Qyestion
The Miscellaneous you see in the cost sheet is the two user created boards on your upper cabinets. As of right now you can not set a value to these. Also I noticed there was a profile on them, are you wanting to machine these parts at the CNC? If so, you can not do this with a display board. They will have to be made out of a cabinet top. Here you would load a cabinet in the cabinet editor delete everything but the top, put your profile on it and set your cost. Now you can add this to the room and it will be included in your sheet cost. If you have any other question feel free to contact me.
