part editor ?
Darren Harvey
part editor ?
Post by Darren Harvey »
i'm trying to make a wine rack. the question is that i need to place 2 display panels, or a stretcher in. i also need to take it in part editor and cut out wine holes to place the wine in. i can take a display panel in part editor, but i need full dados on all four sides. a stetcher would be great but i can't take that in part editor. any suggestions with my rambling? thanks darren :wall:
Todd Miller
Re: part editor ?
Post by Todd Miller »
Darren,
If you could give me an idea or picture of what you are trying to acheive, I may be able to help you out. You can post it here or send it to program@thermwood.com.
Also, attach the dimensions of the rack.
Darren Harvey
Re: part editor ?
todd, here is the hsf. right know i have a display panel in there. what i need is a full dado all around, and be able to take it into part editor. i guess what i want is the best of both worlds. i would like to use a stretcher, but i can't take that into part editor. thanks darren
venue wine rack.hsf
(174.02 KiB) Downloaded 470 times
venue wine rack.jpg (12.3 KiB) Viewed 7538 times
Darren Harvey
Re: part editor ?
todd, to give you an idea what we are doing. here is another picture. we took 2 cabinets. 1 we did full dados through part editor on all 4 sides. the 2nd cabinet we made the right sizefrom the back and gave it a inset toward the front. the 3rd cabinet we did the same as the 2nd cabinet. this was a little long to do. i hope you have a faster and easier way to do this. thanks darren
wine cab1.jpg (13.16 KiB) Viewed 7517 times
wine cab2.jpg (20.23 KiB) Viewed 7517 times
Re: part editor ?
Hi Darren
Try this one it can be resized
I used just 1 display part and that is the top.
When you look at the front it is the bottom of the cabinet in the program.
Let me know if this helps
Wine Cab_4.jpg (37.9 KiB) Viewed 7428 times
Wine Cab_5.jpg (57.56 KiB) Viewed 7425 times
Wine Cab Test.zip
(220.52 KiB) Downloaded 509 times
Todd Miller
Re: part editor ?
Thanks George! I kind of got swamped here, but thanks for adding the file.
Darren,
George's example looks like the best way to make it resizable.
Darren Harvey
Re: part editor ?
thanks guys, it sure did the job and alot easier. now i can leave on vacation and concentrate on scuba.
Darren Harvey
Re: part editor ?
hey guys- thank you so much for the inputs. but i tried something a little different. width 14.5", depth 23", made the front a strecher, lost the right side, and gave it 2 partions. also i got all my settings right, full dados right, and was able to go into part editor and load the dxf's for the hole cut outs. i could of used 1 partion and left the right side on, but this worked. thanks guys for the help darren
wine rack.jpg (44.5 KiB) Viewed 7293 times
