I'm wondering what is the fault module "StackHash_fd00" and could it be because of the overclocking ???Problem Event Name: APPCRASH
Application Name: ECABINETS.exe
Application Version: 5.2.19.0
Application Timestamp: 492abd05
Fault Module Name: StackHash_fd00
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 00000000
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 4105
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Something else to play withCPU Properties
CPU Type QuadCore Intel Core 2 Quad Q6600
CPU Alias Kentsfield
CPU Stepping G0
Engineering Sample No
CPUID CPU Name Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
CPUID Revision 000006FBh
CPU VID 1.1625 V
CPU Speed
CPU Clock 2033.8 MHz (original: 2400 MHz)
CPU Multiplier 6x
CPU FSB 339.0 MHz (original: 266 MHz, overclock: 27%)
Memory Bus 542.4 MHz
DRAM:FSB Ratio 16:10
CPU Cache
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 2x 4 MB (On-Die, ECC, ASC, Full-Speed)
Motherboard Properties
Motherboard ID 65-0410-000001-00101111-081508-Bearlake$A0948000_BIOS DATE: 08/15/08 21:00:54 VER: 08.00.12
Motherboard Name Asus Rampage Formula (2 PCI, 3 PCI-E x1, 2 PCI-E x16, 4 DDR2 DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
Chipset Properties
Motherboard Chipset Intel Beachwood X48
Memory Timings 5-5-5-18 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
DIMM1: Transcend TX1066QLU-4GK 2 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM3: Transcend TX1066QLU-4GK 2 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
BIOS Properties
System BIOS Date 08/15/08
Video BIOS Date 06/09/08
DMI BIOS Version 0410
Graphics Processor Properties
Video Adapter Asus EAH4870
GPU Code Name RV770 (PCI Express 2.0 x16 1002 / 9440, Rev 00)
GPU Clock 500 MHz (original: 750 MHz)
Memory Clock 1800 MHz (original: 900 MHz, overclock: 100%)
