space fillers for european style cabs
John Larson
How do I put "space fillers" in my designs?
- DanEpps
- Company Name: Dan Epps
Re: space fillers for european style cabs
Do you mean a filler between two cabinets?
If so, it depends on how you make them. Is it just a panel? You can make a filler from a standard cabinet. Just start with a standard cabinet and, in construction settings, remove everything but the back. Now resize the "cabinet" to whatever size you need for the filler and add it to your room layout.
John Larson
thanks Dan
Bill Lumley
- Company Name: Bills Custom Cabinets
Is there a way to add filler strips like this that do not get cut . I don't want these skinny strips showing up in my nest as I make them from scraps
and size on site .
Thanks Bill
and size on site .
Thanks Bill
- Gary Puckett
You can re name the material you make the fillers with then just ignore that material in the cut list
Bill Lumley
Duh ..... Sometimes the obvious escapes us . Thanks Gary
Leo Graywacz
Or you can make it out of a display cub. They won't show up in a list, but are not re-sizable.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
jason galbraith
- Country: AUSTRALIA
I find that if you are nesting make a material that has the dimensions of 1mmx1mm, then when you go to nest, it can't use that piece cos it's too big and will delete it from the cutting list altogether and you won't have to ignore it. I tried making a material called "do not cut", but guess what, it created too many problems on the floor:)
www.eastcoastultimate.com.au
