E-Cabinets bug
Sergio Fetter
Company Name: Two Mile
E-Cabinets bug
Post by Sergio Fetter »
Hello Everyone.
I am having some problems with my e-cabinets after the last update. I was working in a layout, I right clicked> adjust cabinet features> duplicate to the left... and then, next thing it e-cabinets did not respond anymore.
Then, I started all over. Once I got done, I saved the job... and again it would not respond.
Does this happen with anyone else besides me? Or am I pushing the wrong buttons??? :?:
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Walker T Scott
Re: E-Cabinets bug
Post by Walker T Scott »
Sergio
Could you attach a job and I’ll take a look at it.
Sergio Fetter
Re: E-Cabinets bug
Walker,
Thanks for the quick answer.
Unfortunately the job didn't save. However, I am working on it for the 3rd time... Hopefully, I will be able to get it this time.
I will post as soon as I have it.
Thanks!
Sergio Fetter
Designer Specialist
Walker T Scott
Re: E-Cabinets bug
Sergio
Could you attach the cabinet that you are trying to duplicate to the left?
Sergio Fetter
Re: E-Cabinets bug
Here it is.
As soon as I have the job I will post it to you.
Thanks!
Blind_corner.hsf
(696.02 KiB) Downloaded 747 times
Sergio Fetter
Designer Specialist
Walker T Scott
Re: E-Cabinets bug
Sergio
Try this delete the door and drawer from the cabinet for now. Then try to duplicate to the left with it and let me know it ecabinets still locks up on you.
Sergio Fetter
Re: E-Cabinets bug
Hello Walker,
No... it didn't work. Furthermore, I tried in couple different cabinets and the results are the same.
It is not that is complete locked up, I can minimize and maximize. It is like in a eternal processing that never works.
Surely is not my computer, is it? :wink:
Sergio Fetter
Designer Specialist
Re: E-Cabinets bug
Sergio Fetter wrote:...Surely is not my computer, is it? :wink:
What are the specs on your computer?
Lamar Horton
Re: E-Cabinets bug
Post by Lamar Horton »
I have never had much luck with the right click, duplicate right or left, expand to fill or the change size when loading a cabinet into a room.
What usually happens when duplicating a cabinet is the original cabinet re sizes itself, usually smaller, and the duplicated cabinet is a totally different size and they often overlap the wall or cabinet in the space I am trying to fill.
Leo Graywacz
Re: E-Cabinets bug
Post by Leo Graywacz »
I tried it and it seemed to work at first, but it ended up being in an endless loop. It kept showing the drawers being built alert box. After it built 16 drawers, with a cabinet that only had 4 drawers I terminated it.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Sergio Fetter
Re: E-Cabinets bug
In fact, I tried couple other times and it didn't work.
Dan this is the specs of my computer
DELL LATITUDE D630
INTEL CORE 2 DUO CPU
T7300 @ 2 GHz
1.99 GB OF RAM
I appreciated all the input.
Thank you very much!
Sergio Fetter
Designer Specialist
Re: E-Cabinets bug
Sergio Fetter wrote:In fact, I tried couple other times and it didn't work.
DELL LATITUDE D630
T7300 @ 2 GHz
1.99 GB OF RAM
Video card?
Sergio Fetter
Re: E-Cabinets bug
No video card. I never had a problem without the video card except for that now.
Sergio Fetter
Designer Specialist
Re: E-Cabinets bug
Sergio, if you look at the adjustable shelf you will note that it passes through the right side. I deleted it, then re-added it, came back to main and lost the drawer box, re-added that, saved. It worked after that.
Re: E-Cabinets bug
What I don't understand is why do you want to Duplicate Left a blind corner cab?
