Creating a new door
Sergio Fetter
Company Name: Two Mile
Creating a new door
Post by Sergio Fetter »
Hello everyone,
Is there a way that I can create a door and have applied molding to it. I am trying to get a door with rope molding around the door.
Can anyone give a suggestion.
Thanks!
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Re: Creating a new door
The only way I know of is to add the door then manually add the molding. The only thing is that you will have to overlap the ends since the automatic miter will be in the wrong orientation.
Sergio Fetter
Dan,
Thanks for the answer.
The only problem that I have with that is... If I have 20 doors, I will have to do one by one??? :idea:
Sergio Fetter
Designer Specialist
Yup. Someone else may know of an easier method but I don't.
Sergio,
Use the Conestoga Saxony Door from standard doors. It already has the rope molding on it.
I knew someone would have a better way. :beer:
