Hi, we are a wardrobe manufacturer and one of clients does specialty kitchens, and sends them through to us to nest on our thermwood CNC. He does a lot more cabinet development than us, and he has run into problems that we cannot solve, so I thought I would pass it on here.
regards
Jason
Message as follows
I would like to know how to fix the errors with hole patterns. I am finding when I make any changes to a raw shelf with my KD fitting, such as adding edge banding, making a profile cut (such as a U-shaped shelf), the hole pattern appears as red instead of blue in the CNC Nest preview. In turn, the CNC has trouble reading the hole pattern, including errors and choosing the wrong cutter, leaving a chunck in the middle of the hole. I have tried re-designing the hole pattern, but no good. I would like to see it fixed, rather than bandaid solutions.
I have attached a carcus with these problems, as well as the hole pattern I use. I would really appreciate your time to find a solution.
Kind regards
Brendan
Associate of Jason at Eastcoast Ultimate.
- 20kd.zip
- and hole pattern
- (2.63 KiB) Downloaded 516 times
