Resize Cabinet problem
Paul Amos
Company Name: Fretworks
Post by Paul Amos »
I look forward to joining the eCabinets forum now the software has been made available to Shopbot owners.
I need a bit of help, please.
I am try to resize a cabinet from the frameless 32 system, everything resizes ok except the base, what am I doing wrong ?
Paul
Magical Snap - 2009.04.11 11.11 - 002.jpg (22.01 KiB) Viewed 11678 times
Re: Resize Cabinet problem
How are you going about resizing the cabinet? Put the new size in the size box and press "enter" and it should resize correctly (although I haven't downloaded that library and tried on them).
Gary Puckett
Company Name: The Woodworkery
Post by Gary Puckett »
Paul,
Have you tried deleting the deck and then adding the deck back?
Paul Amos
Post by Paul Amos »
Thanks Guys
Dan,
That's how I resized the cabinet.
Gary,
I tried your method and it worked fine, but I lost all the fitting holes, so I think it is a constraint issue.
Paul
Paul Amos wrote:...but I lost all the fitting holes, so I think it is a constraint issue...
Definitely. Take a look at the constraints and see how they are setup. You can probably change them so the cabinet can be resized.
Kenneth Rychlik
Post by Kenneth Rychlik »
Paul,
Did you resize just before placing it in the room, or after it was already in the layout? It seems to work better for me to resize when I choose the cabinet, but before placing it in the room.
Kenneth
Paul Amos
Post by Paul Amos »
Ken,
I resized it before placing it.
Paul
Paul Amos
Post by Paul Amos »
I found the problem.........
In the constraints settings the first line of leg mounting holes had a setting of 11mm from the end of the panel, this was on the front and the back, I removed the contraint on the back and everything resized fine.
