Paul Amos
Posts: 13 Joined: Wed, Apr 08 2009, 11:57AM
Company Name: Fretworks
Post
by Paul Amos » Tue, Apr 14 2009, 10:07AM
I am trying to create an arched cutout to a L/R stretcher but the Part Editor says that this part type is not supported .....Any suggestions.
Paul
Nick M Singer
Posts: 828 Joined: Fri, Jun 17 2005, 12:23AM
Post
by Nick M Singer » Tue, Apr 14 2009, 10:16AM
Make the stretcher out of a display panel
Rick Deskins
Posts: 858 Joined: Tue, May 17 2005, 12:47PM
Company Name: Thermwood
Post
by Rick Deskins » Tue, Apr 14 2009, 10:17AM
Wait for v6, or use a display panel instead of a stretcher. (Note: display panel will not resize when the cabinet resizes).
Rick Deskins
Paul Amos
Post
by Paul Amos » Tue, Apr 14 2009, 10:41AM
Thanks for the quick response,
I will have to use it with the stretcher and blind dado's so that it resizes with the cabinet, then re-machine the arch after.
What is planned for V6 and when will it be released ? No pressure.
Paul
Posts: 1896 Joined: Wed, May 18 2005, 7:54PM
Post
by Rick Palechuk » Tue, Apr 14 2009, 2:15PM
Post your cabinet Paul, maybe there is something else that can be done.
Paul Amos
Post
by Paul Amos » Wed, Apr 15 2009, 11:44AM
Rick Palechuk wrote: Post your cabinet Paul, maybe there is something else that can be done.
Rick,
Here is the cabinet, the L/R section will have doors the center section is open with an arched rail.
Any suggestions would be appreciated.
Paul
123.esj
(12.02 KiB) Downloaded 1108 times
Magical Snap - 2009.04.15 17.29 - 005.jpg (31.29 KiB) Viewed 21574 times
JohnLashuay
Posts: 645 Joined: Mon, Nov 20 2006, 3:39PM
Post
by JohnLashuay » Wed, Apr 15 2009, 1:36PM
Paul,
As was mentioned before, your best bet is to use a display panel or display cube and take it to the part editor.
Good Luck!
-John
Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Wed, Apr 15 2009, 6:17PM
Paul
I used a sheet stock face frame and removed everything but the top rail with some insets. I also used negative insets on the left and right sides as well as the deck and toe kick.
The arch has constraints so you can re-size.
I forgot to do your top like you have it.
I couldn't open your job file, it is only 12 KB
Post
by Kerry Fullington » Wed, Apr 15 2009, 6:37PM
Here is a shot with the top overhang
Paul Amos
Post
by Paul Amos » Thu, Apr 16 2009, 1:58AM
Kerry,
Thank you, that is exactly what I was looking for.
Paul
JohnLashuay
Post
by JohnLashuay » Thu, Apr 16 2009, 8:00AM
Way to go Kerry!! All the rest of the posts say it can't be done and you prove us wrong.
Great work as usual
-John
Rick Deskins
Post
by Rick Deskins » Thu, Apr 16 2009, 8:04AM
The only thing the face frame solution does not allow is the blind dados. keep this in mind.
Rick Deskins
Posts: 1585 Joined: Tue, May 17 2005, 1:16PM
Post
by George Davidson » Thu, Apr 16 2009, 10:09AM
Would this help
Test 4-16-09.zip
(98.54 KiB) Downloaded 987 times
Test Cab 30 x 34. x 24_2.jpg (98.04 KiB) Viewed 21369 times
Test Cab 30 x 34. x 24.jpg (95.21 KiB) Viewed 21368 times
Paul Amos
Post
by Paul Amos » Thu, Apr 16 2009, 10:40AM
Hi George,
What part did you create it from ?
Did you use the contour editor to create the shape ?
Many thanks
Paul
