Unassociated Hole Pattern?
I've created the hole pattern for a KD/RTA fitting that's different from the selections that are available to associate it with (Hafele products). I've saved it in my 'patterns' folder, but can't figure out how to retreive it from the KD setting fields available in cabinet editor under construction settings. Do I need to create a new item to associate it with, and if so, how? Thanks.
Re: Unassociated Hole Pattern?
You need to first off have RTA selected for your construction method. You then need to pick some RTA hardware to which you will associate your new hole pattern. Just pick an RTA part you are not likely to use. Unfortunately we currently do not have access to the parts database, so you can't create your own new hardware item. I am hoping that is one of the changes for version 6.
Joe
Joe
CFT411 http://www.cft411.com
I did end up doing that, which works, but I agree that it would nice to be able to create new hardware items. Thanks.
