If, for example, you call for tool #3 and THAT TOOL IS ALREADY IN THE ROUTER HEAD when you push start, the motor will start up and immediately put itself into e-stop. If there is a DIFFERENT TOOL IN THE HEAD, it will drop that one off, pick up the one you call for, the motor will start and it will run fine. So, I can still run parts, but I have to make sure I've got a different tool than what I am using in there or I get the error. I've tried with all the different tools and tool holders, but that doesn't seem to be the problem.
The error I get when this occurs is:
Z Draw bar not up while spindle is moving (Input 2 open or 1 closed) & (15 open or 11 closed)
When I watch the input or output screens during a tool change, everything looks like it is functioning properly.
I'm still trying to work this out with tech service but wanted to post on here to see if anyone else has a fix.
Thanks in advance for any help
Saul
