Angle Cabinet Sides
reedwatts
Angle Cabinet Sides
Post by reedwatts »
I am attempting to design a slant-front desk (secretary) and can not figure out how to angle the sides....
JohnLashuay
Re: Angle Cabinet Sides
Post by JohnLashuay »
You need to take each side panel to the part editor to cut the angle that you are looking for. You will also need to give the top shelf a front inset that will bring the front back to where the angle ends at the top of the panels.
-John
http://www.rylexonline.com
Thermwood CS 43
reedwatts
Post by reedwatts »
John --
Thank you for the reply. I hate to ask, but is it possible to walk me through it...how do I get into the parts editor...
reedwatts
Post by reedwatts »
John --
OK. This is how far I can go....How do I cut off the "triangle"?
JohnLashuay
With the picture that you are showing, take the "Filled Arc" (Half Circle) and apply it to the angle. Then highlight it and right-click, click on the "cut/Pocket Using Closed Contour". This will bring up a window that will give you an option to cut through or specify a depth. Check the "cut through" and then OK. This will remove that material.
Then highlight the little box that is in front of the shelf and do the same to remove that material.
-John
Thermwood CS 43
Try the steps in this video:
Angled Top Cabinet.zip
(3.98 MiB) Downloaded 485 times
If you make a DXF in SketchUp just your side then bring it into e-cab
reedwatts
Post by reedwatts »
THANK YOU DAN EPPS!!! I have been trying for a while to figure this out!!!
reedwatts wrote:THANK YOU DAN EPPS!!! I have been trying for a while to figure this out!!!
No problem! You can find this and a few other videos I've done on my website eCabWorld.
Reed,
There are also several good video tutorials available through eCabinets. On the opening screen of eCabinets select View Video Tutorials. There is one on the part editor. as well as other areas of the software.
