Thermwood Corporation
Thermwood offers an entire line of high production, multi-head CNC routers well suited for volume production of furniture components made from either sheet stock or solids. Whether you are building upholstery frames, chairs, tables or elaborately carved case goods, Thermwood has a system ideal for your application.
Thermwood’s furniture machines are heavy duty, high speed and highly reliable using fully stress relieved steel construction, intelligent Siemens drives throughout and the most technically advanced and capable CNC control on the market today, the Gen2 SuperControl. Each machine is volumetrically laser compensated in three dimensions for maximum accuracy, a feature not available from anyone else in this market.
Thermwood systems for volume furniture production include the following:
Model 42 CNC Router
Model 42 - Dual table machine with up to four automatic tool change spindles in table sizes from 5’x5’ to 5’x12 foot. Machine on one table while loading and unloading parts on the second table. A true high production, multi-purpose machine.
Model 53 CNC Router
Model 53 - High speed, roller hold-down machine for volume production of nested upholstery frames. Available with automatic load/unload and ultra high cutting speeds. Run high volume standard nests or nest and cut right at the machine control for the ultimate in flexibility.
Model 63 CNC Router
Model 63 - Fixed table high machine for volume production of long parts or long carvings. Available with up to four automatic tool change spindles.
Model 83 Carver
Model 83 Carver - Fixed table carving system with up to 6 automatic tool change spindles for volume production of flat components or flat carvings.
Model 80 Carver
Model 80 Carver - Four axes, eight spindle moving table system for volume production of three dimensional carved parts including legs and posts. Includes eight position automatic tool changer for each spindle. All tools are changed at the same time for true high speed production.
Model 96 Part Processing Machine
Model 96 Part Processing Machine - Four axis, ten spindle, dual table machine for volume processing of solid wood parts or carvings. Load and unload one table while processing parts on the other for maximum throughput. Each spindle has an eight position automatic tool changer. All tools are changed at the same time for true high speed production.
Request More Information
a
See Us on YouTube
Proudly Made in the USA
Trade Show Schedule
Thermwood Forum
a
