Thermwood / eCabinet Systems • View topic - Profile modle- No data found
  • Advertisement
Moderator: Jason Susnjara
Postby Alex Bowler » Mon, Apr 16 2012, 5:29PM
Hi,
I would like to start using the profile modeler but i am unable to load any job. It comes up with an error message saying
no part editor data found in database.
What do i need to run it?
My main use would be to machine miters that i apply in part editor.
Alex Bowler
Company Name: cutshop
Country: NEW ZEALAND
Re: Profile modle- No data found
Postby Scott G Vaal » Tue, Apr 17 2012, 11:01AM
Alex,
You must have a {profile cut path} before you can load the item into Profile Modeler. Profile modeller only machines these type cuts/operations. How did you create the miters?
Scott G Vaal
Postby Alex Bowler » Tue, Apr 17 2012, 2:54PM
Hi,
I created a tool using shape manager (v cutter) then applied that to the part using profile edge. Do I import the hole cabinet or just the part with the miter?
Alex Bowler
Postby Scott G Vaal » Tue, Apr 17 2012, 3:09PM
Alex Bowler wrote:Hi,
Alex, You would create CNC from the cabinet, assembly, or job and then load the *.twd file that was created. If you continue to have trouble with this, please attach the cabinet here and I can try it.
Scott G Vaal
Postby Alex Bowler » Tue, May 01 2012, 3:50AM
Hi
Sorry for the slow reply got dragged into some thing else. I am not sure why but when i tried importing a cabinet with a miter now it let me. I am not sure how
to use profile modler but should be able to figure most of it out now i can start. Is there and video tutorials on how to us it?
Alex Bowler
Postby Scott Marshburn » Tue, May 01 2012, 5:01AM
Hi Alex Here is a link to the profile modler manual this should help get you going.http://www.thermwood.com/twood_site/pag ... manual.pdf
Scott Marshburn
Company Name: B and W Custom Doors
Postby Alex Bowler » Tue, May 08 2012, 11:01PM
Hi,
I am still trying to get the modler to work. I did the sample exercise in the manual and everything worked okay
except it would not create the CNC file. It comes up with an error message say cannot create out put file then the file name.
Any ideas?
Alex Bowler
Postby Scott G Vaal » Fri, May 11 2012, 7:56AM
Any ideas?
This is because the output folder does not exist for some reason. Simply create a folder { D:\Data\Profile_Modeler\CNC-Files } on your machine and then it should be fine.
Scott G Vaal
Postby Alex Bowler » Sun, May 13 2012, 10:15PM
Hi Scott
Getting there it is working on the simple parts now. When I applied an inset carving to the side of a cabinet and tried to import
it in to profile modeler it came up with an error message saying no part editor found inside data base.
Alex Bowler
Return to eCabinet Systems Software
Users browsing this forum: Bing [Bot] and 2 guests
