Using the f/x editor
Carmen Addamo
Postby Carmen Addamo » Sun, May 14 2017, 7:02PM
Can someone enlighten me as to its purpose. I have been trying to figure out a way to lock the width of a fixed shelf to 4" for example no matter the cabinet depth but haven't figured out a way
Scott Marshburn
Re: Using the f/x editor
Postby Scott Marshburn » Mon, May 15 2017, 7:49AM
Hi Carmen. Here is a video where I demonstrate this feature for half shelves.
https://www.youtube.com/watch?v=D07KS8e ... U&index=15
Hope this helps
Brad McIntosh
Company Name: CNC Automation
Postby Brad McIntosh » Mon, May 15 2017, 8:09AM
Try the following in the "Shelf/Partion Editor":
CabinetDepth-BackThickness-4.00000000000000-0.25000000000000
Where:
  • CabinetDepth is the built in variable for the depth of the cabinet.
  • BackThickness is the built in variable for the thickness of the BACK.
  • 4.0 is YOUR Fixed Shelf Width desired.
  • 0.25 is YOUR "Back Inset" of the BACK component. (Change this to match your construction method's BACK "Back Inset".)
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Carmen Addamo
Postby Carmen Addamo » Mon, May 15 2017, 7:02PM
Scott and Brad Thank You. I will play with this tomorrow. I'll post back how it went.
Brad McIntosh
Postby Brad McIntosh » Mon, May 15 2017, 7:22PM
carmen,
I just want to point out that I was assuming a "drawer stretcher" sort of application. The same sort of thing could be done when applied to the "Front Offset".
Brad McIntosh
CNC Automation
Carmen Addamo
Postby Carmen Addamo » Tue, May 16 2017, 7:07AM
Brad you are correct in your drawer stretcher assumption :D
Users browsing this forum: Google [Bot] and 39 guests
