Dividers For Cabinet door and drawers
Moderator: Jason Susnjara
Nicholas Kiss
Company Name: Clearcut
Postby Nicholas Kiss » Thu, Feb 01 2018, 10:40AM
So i've been trying to figure out how to add some dividers for my door and drawer so when i close the door it stops on something and im not sure if they have an automatic option for that or if i would have to add a stretcher and manually do it.
~Nicholas
Brad McIntosh
Company Name: CNC Automation
Re: Dividers For Cabinet door and drawers
Postby Brad McIntosh » Thu, Feb 01 2018, 6:03PM
Nicolas,
First off, your inquiry should have been in the "eCabinet Systems Software" forum section.
If you are looking for a "Drawer Stretcher" in a frame-less construction method, then...
In the "[b]Shelf/Partion Editor" -[/b]
  • Add a "Fixed Shelf".
  • Select the "Fixed Shelf" you want to make a "Drawer Stretcher".
  • Right-Click and select "Construction Settings". (This allows you to edit the parameters for the selected shelf.)
  • Modify the "Back Inset" using the "Formula" [f(x)] button.
  • Click the [Depth] button under "Cabinet Dimensions".
  • Then insert "-" and "5" (or whatever width you want for the "Drawer Stretcher").
  • Click [OK] to exit the "Formula Editor".
  • Click [OK] to exit the "Construction Settings" for the selected shelf.
  • Return to the main "Cabinet Editor" screen.
Your cabinet will "rebuild" and you will now have a "Drawer Stretcher" with a fixed width of "5" (or whatever you chose). It is parametric, so it will remain the width..errr...depth (depending on how you look at it) you selected even if you change the cabinet depth.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Return to “Lounge”
