We have an 8 year old CS40 with the manual 1/2" x 1" x 6" locating pins. They have been a PITA for about 7 years now. I called THM to see if there was any new type of pin arrangement and was told my only option was to upgrade to air actuated pop-up pins. After getting the quote and deciding it was not an option, I've been playing around with ideas.
Has anyone else replaced these annoying pins ? I need more ideas.
Dave
Locating pins
- Josh Rayburn
Re: Locating pins
Dave,
I replaced mine with teardrop shaped delrin mounted with shafts from McMaster Carr and some other misc. hardware.
They work a lot better then the wood ones but I also wish the price of the air pin upgrade was not so steep.
Dave Burtchell
Re: Locating pins
Could you post a picture of your pins/shaft?
Your originals were really wood!?
Dave
Dave
Dave Burtchell
Re: Locating pins
Went ahead and bought some cheap 5/8 pillow blocks from Ebay. $5 each. Some military surplus shafts with 5/8 threaded ends. Another $30. Already had some 3/4 Delrin. About $100 all told with mounting hardware. took all day. Threaded the delrin so I could fine tune the position.
So far they work great!
Here are some pics.
Here are some pics.
Wayne Adelkopf
- Company Name: Noble Woodworks Inc.
Re: Locating pins
Awesome setup Dave. Where did you get the threaded shafts from?
Dave Burtchell
Re: Locating pins
Ebay! Air Force surplus
