Ramp for pockets
Kyle Koehn
Company Name: Countryside Cabinet Shop
Ramp for pockets
Postby Kyle Koehn » Mon, Dec 18 2017, 7:50PM
Is there any way to set the ramps different for the types of operations? I am cutting shaker style mdf doors and so would like a larger ramp for my larger fly-cutter type tool that I am using for that pocket operation. But I don't want to use a large ramp for my outline/rout operations.
Thomas strembitsky
Re: Ramp for pockets
Postby Thomas strembitsky » Tue, Dec 19 2017, 11:50AM
in control nestings setting you have options for setting the ramp in length and depth for outline and rout operations
NVIDIA GeForce GTX 950
http://www.trueform.ca
CS43 cnc
Brad McIntosh
Company Name: CNC Automation
Postby Brad McIntosh » Wed, Dec 20 2017, 9:08AM
Thomas,
I believe that Kyle is aware of those settings, but my interpretation is that he would like a separate set of parameters for the "area clearance part" of the Pocketing operation.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Kyle Koehn
Postby Kyle Koehn » Wed, Dec 20 2017, 10:10AM
Yep, What Brad said. Maybe in the pocket area or something. It actually is working now fairly well. I can just set the rout area to one things when I am running mdf doors and then change it back when I am doing other parts. The problem is just when I am doing other parts in the same nest. It is helpful to have that separate setting from the outline cut.
Ian Richardson
Company Name: Millworx
Postby Ian Richardson » Mon, Jan 29 2018, 9:05AM
What about using group settings. Make your Mdf door material separate and apply settings specifically for that group
Brad McIntosh
Postby Brad McIntosh » Mon, Jan 29 2018, 10:07AM
Ian,
Your suggestion is good if Kyle just wanted different "Outline" and/or "Rout/Dado" "Ramp" settings for MDF as a whole.
What Kyle is looking for is differing "Ramp" settings between "Pocket" and "Rout/Dado" operations within the same material. Currently the "Ramp" settings for "Rout/Dado" are also used for "Pocket" operations. He would like to have one set of "Ramp" settings for "Rout/Dados" and another separate set for "Pockets".
Adding a "Pocket Pre-Ramp Depth" and a "Pocket Ramp Length" setting would solve this. (Perhaps if implemented, "BLANK" (undefined) values in either would then have Control Nesting use the "Rout/Dado" settings used by default?)
! - One could go even one step further and have "Operation/Tool Level" "Pre-Ramp Depth" and "Ramp Length" settings for both "Rout/Dado" and "Pocket". Again, if those values are "BLANK" (undefined), Control Nesting could default to the "General Settings" defined globally for that material.
Brad McIntosh
CNC Automation
Kyle Koehn
Postby Kyle Koehn » Mon, Jan 29 2018, 12:13PM
Or even to get to the real heart of the matter would be if I could add a ramp setting to a tool. I am using a flycutter type tool for pocketing out shaker style mdf doors and so a short ramp setting really gets hard on the tool.
Brad McIntosh
Postby Brad McIntosh » Mon, Jan 29 2018, 12:39PM
Kyle,
That is why at the end of my last post I had added...
Brad McIntosh
CNC Automation
Tommy Wieler
Postby Tommy Wieler » Wed, Jan 31 2018, 12:15PM
We also use a flycutter type tool for pocketing on mdf shaker style doors, and we were able to lengthen the tool's ramp-in length by changing the rout/dado length setting
Below are our tooling settings for the pocketing tool.
