Help with this DXF
Help with this DXF
Can not get this to nest...
ACAD using acad 2007
- Roger Erismann
Add on to the above post...
Nano and I were trying several different ways to get this part cut...
1 Load directly into CN and cut(no luck)
2 Load into parts editor and cut(no luck)
3 Adjust the layers in the Acad drawing and cut(no luck)
4 Call thermwood and get a solution(no luck)
So now I suppose that we will attempt loading it into the shape manager and go from there...maybe we will get lucky.
We consulted the sample DXF file in the CN manual and we got that to load up just fine....when I tried to adjust the layers in our part I couldn't get it to load....
the message is \"part exceeds required material thickness, material required 0.0000\"\" so I don't get that either...I am sure there is just a simple setting somewhere to get it to work....
Anyways hope someone can help...
Roger
Any e-cabs to ACAD gurs out there would be very helpfull!!
Roger
Wood Butcher/Case Maker
- Roger Erismann
- Kerry Fullington
- Roger Erismann
Pretty much told me to check the layers on the DXF for the CN out put then told me about the splines and the arcs(which I allready knew)
So I saved it in ACAD 2000(suggested by Daniel I think) and tried to load it up in the parts editor...
We have had many issues with DXF import into e-cabs...it really is just hit or miss with that one for us at least..
I'm gonna add that into the wish list...DXF import manager!!
- Roger Erismann
Roger I tried opening your DXF but it will not. I use DXFs extensively on my Thermwood so If you want mail me any problems you are welcome at nbfsinger@iburst.co.za. The outline layer prescribes the perimeter of the part and the \"z\" variable sets the depth or thickness.
- Kerry Fullington
- Roger Erismann
Like Nano said....
We tried everything out..
ended up getting it to work in the parts editor by saving it in version 12 of ACAD...
The parts were delivered ontime and everything went well...
Now Daniel mentioned something about hidden layers...How do I view those layers so I can get rid of them in the future?
The part was generated by another company and emailed to me....
The upside is that the customer wanted one set of more parts made out of another DXF, Nano was able to knock it out and cut the parts in 15minutes(using version 12 of ACAD and the parts editor)...we still had to go through ecabs...although this is OK we would rather nail these 2D DXFs out in the auto cad format and cut....(screen to machine time)
Love this forum
Love this forum
Roger,
I don't have Autocad so I can't explain how to show hidden items in a layer, or used layers in that software.
I have to do everything in Mastercam.
You can always direct your customer to our website and have them read the control nesting manual so they know how to set up the dxf files properly.
Users browsing this forum: No registered users and 48 guests
