Removing Doors But Keeping Hinge Plate Holes
Stephen Williams
Company Name: John Samuel Custom Cabinetry
Postby Stephen Williams » Fri, Feb 11 2011, 6:44PM
Hello All,
Is it possible to add a door then remove it but keep the hinge plate holes associated with that hinge?
Steve
Gary Campbell
Re: Removing Doors But Keeping Hinge Plate Holes
Postby Gary Campbell » Fri, Feb 11 2011, 10:24PM
Stephen....
Almost. You have 2 choices.
1) Use a "DO NOT CUT" door material (quick easier version) This method preserves the parametric hole geometry placement
2) Using the part editor, copy the hole geometry and apply it to the side panels. This is explained very thoroughly in the Training Videos using shelf holes as an example. It is a good feature to learn.
Gary Campbell
Stephen Williams
Postby Stephen Williams » Fri, Feb 11 2011, 11:17PM
Thanks Gary
Users browsing this forum: No registered users and 42 guests
