Trying to model paneling with a 90 degree v-bit 1/4" deep, down length of a panel. Have a tool group vBit with a single custom tool 90 vBit. Created a generic test cab and put centerline panel lines on the door. vBit is the default group with my 90 vbit as the custom tool. Only one tool in the group. When I load in profile modeler and try to write CNC I get the following message:
"An error occurred while performing the toolpath calculation on region #1. Reloading the part may fix this problem."
Running the latest version of Control Nesting and have profile modeler V2.6.0.6 (Beta 6) <-just downloaded.
Anyone bumped into this one?
Fred
profile modeler crashing
FredHirsch
Fred Hirsch
- Kerry Fullington
Re: profile modeler crashing
Fred,
Did you re-size your panel that contained the tool paths before writing the twd.
When I get that error I usually have to take the part back to eCabinets and re do the tool paths.
FredHirsch
Kerry,
Thanks for the quick reply. I thought of that and did start fresh with a new cab and am still getting error. Here is generic cab with my V test on door. This cab gives error on the machine. I'm thinking I have setup profile modeler wrong on controller.
Fred
Fred
- 90 Degree V.tol
- 90 V Tool
- (2.99 KiB) Downloaded 1085 times
- VBit_Test.zip
- V-bit test Cab
- (93.1 KiB) Downloaded 1047 times
Fred Hirsch
- Kerry Fullington
Fred,
It worked when I nested your cabinet here.
Make sure you have something like a 10" stepover on your tool in the Profile Modeler tool setup so it won't try to model it.
FredHirsch
Kerry,
That worked in profile modeler. I was able to write the file out of PM. Thank you. Should I be able to do this in the nest? I just tried, and it crashes CN when I go to write the NC file.
Fred
Fred
Fred Hirsch
- Kerry Fullington
If you have your tooling setup in the profile modeler and it works there it should also work in the nest as long as that v bit tool group is your default in provile modeler when you nest it.
Were you trying to do it with the region one and two in mdf doors?
FredHirsch
Kerry,
Sorry for the delay. No these are not MDF doors, but side panels using the Geric 3/4 Material. The interesting thing... if I setup PM to model it everything is great. It has something to do with how I have that custom tool setup in eCabs or PM on the machine. I'll keep trying and let everyone know what I come up with (if anything).
thx
Fred
thx
Fred
Fred Hirsch
