importing a DXF File
Chris B Campbell
Post by Chris B Campbell »
Hey All,
I use Bobcad quite a bit. Normally I just use it as a stand alone and cut whatever I need. I was searching through my E Cabinets program and I do not see any way to import a DXF file into E Cabs so I could include it into a batch file with other parts of the same material... Possible??
Chris
Stuart Douglas
Re: importing a DXF File
Post by Stuart Douglas »
More than one way to skin a cat, but here is one way I know of:
Create a display panel of appropriate material and overall size.
Take panel to the part editor and click on the contour button in the toolbar.
Load your dxf file into the contour editor. Use the dxf vectors to define operations on your part as normal.
Review and save using the toolbar buttons, then add the panel to your list.
Not sure which machine you are operating, but Control Nesting on Thermwood machines can load a properly formatted (layers) DXF right into a nest. I do this all the time when nesting smaller parts or jobs of like materials. There is an ADD DXF dialog box in the Control Nesting user interface.
_____________
NVME SSM2HD 1TB NTFS
Chris B Campbell
Thanks for the reply Stuart,
So exactly how are you loading the DXF file into the contour editor?
Chris
Thomas strembitsky
Post by Thomas strembitsky »
in the contour editor there is a folder icon beside the blue floppy disk that lets you load your dxf file.
http://www.trueform.ca
CS43 cnc
