Can't Find a feature
- Georgi Baltov
In the new release there's an option "Allow drawer box construction to drawer front when drawer box front does not exist". I can't find that one. Where is it?
Top Notch Cabinets
- Georgi Baltov
Re: Can't Find a feature
I found out something but it doesn't seem to work completely. I made the bottom blind dado into the drawer front but I can't do it with the sides.
In my drawer box designer I remove the drawer box front and set the bottom to blind dado into the front. I set the same for the left and right sides. When I click OK I can see the blind dado appear on the bottom but no change on the sides so when I add a drawer in a cabinet the blind dado only shows on the bottom of the drawer front. Can someone check this on and let me know if it works.
Top Notch Cabinets
- Georgi Baltov
I can definitely use this feature. I managed to make eCabinets to show the blind dado construction on the sides as well but when the drawer is added the blind dado is still only present on the bottom of the box attaching to the drawer front. There must be a bug or something in here.
I am actually really excited about that feature.
Nice addition Thermwood.
Top Notch Cabinets
Rick Deskins
- Company Name: Thermwood
Change you flush setting for the sides. Then your box should show the blind dado for the sides and bottom.
Rick Deskins
