steps: load a job and nest it. using the manual nest toolbar click select, select a piece and then click move freely, move the piece and then every piece will move off the sheet. please see attached picture. this is useful feature please fix
Edit: no issue in version 6.20
manual nesting broken 6.22
Intel(R) Core(TM) i5-6400 @ 2.70GHz 8.00 GB RAM
NVIDIA GeForce GTX 950
Windows 10 Professional 64-bit
http://www.trueform.ca
CS43 cnc
CS43 cnc
Re: manual nesting broken 6.22
Thomas,
Thank you, we have seen the issue as well. It has been there for a little while before that just not nearly as bad. It does still work, it's just the view is becoming tilted. You can press the Home key on the keyboard and the view will reset back.
thanks for the work around
CS43 cnc
CS43 cnc
