fin to wall toe board
I have a finished left cabinet with a right wall end. I have a frame hangs over 1/2 on the wall end, but unable to extend the toe to match. Simple fix?
Re: fin to wall toe board
Set the right scribe of the toe kick to -.5 plus whatever your side material thickness is. You will have to cut the toe notch deeper manually or with the part editor. Just for future reference you will probably get more responses quicker if you post questions like this in the software area.
Not sure where you are seeing this option?
think I'm getting it..
Thx... Working out one problem at a time.
On to problem number two.
