My round wall
My round wall
Wall is 1 1/2\" T
RodneyDuncanson
Post by RodneyDuncanson »
how did you do this
Nick M Singer
Post by Nick M Singer »
And how long?
Wall 6\" x 96\" H
First wall long 6\"-340 degrees
next wall long 6\"-320 degrees
next wall long 6\"-300 degrees
around to wall long 6\"-200
Ingenius, George!!! Tedious, but ingenius.
George,
I think I will stick with a wall cut from a display cube. Much faster and you probably have to place cabinets etc. manually using either method.
Or Maybe an S Curve.
Dean Fehribach
Site Admin
Post by Dean Fehribach »
Kerry, now you're just bein' a show-off :lol:
That is COOL, George. 8)
Dean Fehribach
I.S. Mgr., Thermwood
Tom Houser
Post by Tom Houser »
That's just wrong Kerry. Very Kewl but wrong.
Thom Houser
http://www.thouser.com
A person who never made a mistake
never tried anything new.
A. Einstein
Paul Huff
Post by Paul Huff »
Nice work guys :!:
I have not had to do anything like this yet. But it is nice to know that it can be done.
Brian Shannon
Post by Brian Shannon »
Hey Kerry! There's your wife's plants again!
Wayne Burrell
How
Post by Wayne Burrell »
Hey Kerry,
How did you do that?
Wayne
Wayne,
Create a Display Cube in the Cabinet/Assembly Editor. The width of the cube is the width of your round wall (or a little more if you want)
The length of the wall is the radius of your round wall plus some extra.
The Depth is the height of your round wall. The texture can be anything as it can be changed in the room.
Take this cube to the Contour Editor.
Click the circle tool and choose Three Point Arc.
Create an Arc that matches the outside diameter of your round wall.
Click on the Copy/Move tool and select Move and enter a value equal to the thickness of your wall and click OK.
Click on the arc you created then move the cursor toward the inside of that arc and click again. You should now have another arc inside the first.
Select the line tool and draw lines from both arcs like this
Exit the Contour Editor then right click and choose Cut Pocket using Closed Contour.
Click on one of the contours and it will turn green.
Click the next button and select Cut Through and then OK
Repeat for the other Contour.
You should now have your wall.
Click return and choose to save the changes when prompted.
This wall can now be saved as an Assembly to use or you can export it to the display parts editor to make the textures work better and save it as a Display Part.
This is placed in a room just like an assembly or display part. To make the S curve simply place two of these walls and rotate on opposite the other.
Mike Seisser
Company Name: NCB Inc.
Post by Mike Seisser »
Hi Kerry,
I just finished a drawing for a room we're starting next week, using your display cube tip. Works great, and incredibly easy.
Question: Now that I've manipulated the software to make the curved bench seat, how do I create doors or raised panels to match? I can create a slab, but because I must create them from the top view, the path to profile the edge(s) isn't available to me.
Any suggestions?
3-4 View w Curved Bench.jpg (126.46 KiB) Viewed 32947 times
Mike,
I am wanting to do the same thing but haven't found a way yet. I have some curved front vanities that I want to add panels to.
I also wish there was a way to smooth the arc segments on these walls when they are rendered so the walls don't show lines so bad. Georges wall seems to have handled that better. It may be the solid color used.
