David,
I highlight the door in the 'door/drawer' editor and the 'main' editor, but the match texture is not highlighted, as if it is not an option. It is a Conestoga Presidential door. Thanks again, Mike
You must be in the \"Main\" section of the cabinet/assembly editor.
You must select the door. (single click the door and it gets a green grid)
You must Right Click ON THE DOOR.
Select \"match Texture\"
Click on something that is the color you want the door to become.
Mike,
When you select your door, make sure you don't have \"Purchased Finished\" checked. If you choose a door purchased finished you cannot change the texture.
I am having a similar problem in that I cannot change the texture of my faceframe. I can do it for the doors however. When I create the faceframe it is in the stock I desire (Cherry w/Cordavan finish) but once I add the door (which is a Conestoga Door in Cherry - no finish available) and then go back to main my door is in unfinished cherry and the frame reverts to match the door. Going back to faceframe or door manager after changing the door things look OK - but once I then go back to main my face frame is left orphaned in the original cherry finish. Any ideas?
In Door Editor things look like they'll be OK after having already matched texture for the doors in Main. Face Frame looks to be in the proper stock as well...
FaceFrame Problems.JPG (40.79 KiB) Viewed 22404 times
Now back in Main the Face Frame reverts to unfinished cherry...
FaceFrame Problems 2.JPG (51.77 KiB) Viewed 22402 times
You must go to construction settings/ face frame tab/ page 2 and un-check common finish with door then go to preferences/define stock materials/ board stock and change the texture for your board stock.
