Replace material Bug
Nick M Singer
I have had a rather nasty little bug eat two of my jobs and wondered if anyone else had the same problem. For some arcane reason one fine day when I opened a job a dialogue popped up regarding a \"new material found\" or \"same material found but with a different thickness\" . as we all know the feature to replace the material is still after all this time not functional so I pressed \"cancel\" and the job then opened with a perfectly empty screen. The file is still there and has a size of over 7meg but you can see nothing and no room exists. Goodbye all my hard work!!! AAAAAArrrggghhh!!!
Nick,
I also am having some problems with this recently. Scott Vaal and I are trying to figure this one out. My job did not go bye-bye but it was worthless by the time I was done with it. The part that I love the most was when ecabs created its own material and kept prompting me to use it when it didn't even exits in my sheet stock. The truth of the matter is you are probably better off losing the job than mucking around with it for 2 days just to scrap it anyway. Definitly send the job to Scott Vaal so he can trace this one.
Nick M Singer
Hi Dan & Forest I did add the new material and found that it changed two units into that particular material. I then changed them back to the correct material and saved, When I went back to the job the same dialogue came up and that is when I cancelled and the rest is history as they say. I will forward the file to Scott
Nick M Singer
Michael Rodgers
I have seen the same problem myself. The main occurance was when I set a material to 23/32\" thickness. We use a lot of import birch plywood for cabinet interiors and when I setup the material it would work fine except when a partition was involved then the same bug as seen before would pop up. Very irratating as I almost had my cabinet library done when it hit. I wound up just deleting everything and will be waiting for a fix before I put ecab to some serious use. Just a thought I have another program that I have used for years without any problem. It handles dimensions by rounding them to the nearest unit that you specify. Maybe this could fix the bug involved with ecabs. Just a thought even though it seems a little long winded.
Floyd Meredith
BenRatt
When I open this cabinet I get the material not found window. It is for Generic edgebanding for a door, but there is no door associated with the cabinet. I get this on most of my cabinets, even though most don't have doors on them.
- Catalog 36in Bev.hsf
- (224.79 KiB) Downloaded 1399 times
Walker T Scott
