after loading a cabinet. going to drawer box editor. i open drawer box designer. open the window to load drawer. when i click on any of the drawers. i get 'e-cab systems application error must close program\" then the program shuts down.
this has worked for me before. so some how i've changed things.
i've tried this with standard cabinets and my own with same results.
i have the latest build/update.
i went back to make sure i wasn't trying to add a front. i'm just trying to add a drawer box. trying to pick drawer in drawer designer is where i'm getting error message. i've rebooted the system no change.
dan, yes i'm trying to load from drawer boxes. i've rt clicked to open window where you can click to \"load item\" brings up \"place items\" window. click on drawer boxes. hit open file icon. select any drawer. i can select a drawer. then when i hit set as default or close i get error message and e-cab shuts down.
when i've tried to load a drawer by clicking on the drawer editor icon. i get as far as trying select a drawer . then i get error message.
You are using the latest build of eCabinets (build 12) right? There was an issue like this with one of the earlier version 5 releases and the drawer boxes were replaced in a later release.
if i've installed build 12. read info list on last few builds and didn't see my problem listed. i was going to try installing previous builds incase i missed one. i couldn't find where to down load previous builds. is there a place i can find a link to these? thank you.
