How to put crown on back side of Cabinet?
Jeff Blewitt
Post by Jeff Blewitt »
Does anybody know how to do this?
-Jeff
You have to add it manually via Add Item. You will have to specify the length and any miters when you choose the molding. Once it is loaded in the workspace, you will have to place it manually.
Jeff Blewitt
Dan,
Can you do a little more blow by blow?
-Jeff
Sure...click the Add Item icon (the same one you use to load a cabinet). On the dialog that is displayed, click the moldings radio button then select the vendor (most likely Conestoga) and the molding. At the bottom of the dialog you will enter the length and miter angles for each end.
To get the proper length, check the front molding before loading the back molding.
Add Molding.jpg (58.92 KiB) Viewed 5905 times
Jeff Blewitt
Thanks Dan, I can see other ways that process can be used too.
-Jeff
Yep! Anything (almost) that you want to add and manipulate manually gets added this way.
Doors, drawer fronts, drawer boxes, moldings, display boards, display panels. display cubes, display objects and certain hardware can all be added and manipulated in this manner.
